Layer 2 view in Campus Manager is not Refreshed automatically
Jul 15th, 2007
I have LMS 2.5 on server and on the clinet side i have java client 1.6.0 installed on the client PC , the topology page is not getting updated when the device become red.
i need to reconnect to the server to Update the Screen.
Overall Rating: 5 (1 ratings)
Joe Clarke Sun, 07/15/2007 - 05:18
Java Plug-in 1.6.0 is not supported. You can only use the JPI that ships with LMS. This can be found under NMSROOT/htdocs/plugin. You must uninstall all other versions of the Java Plug-in on your client, and install the correct, supported version.
