IP to IP gateway, when to use it ??
Jul 15th, 2007
hi,
I'm working on the gatekeeper and gateways exam. I reached the last chapter of the book, which is "Cisco multiservice IP to IP gateway", and I was just wondering whether it is worth spending loads of time on this chapter, as it appear to be used only by Service provider. I work only in medium company network, could I come accross this feature even in a company LAN network ??
if yes, is it something that is frequent ?
thanks a lot in advance
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Sun, 07/15/2007 - 08:15
Yes, you can.
For example it appears that CCM in some versions cannot do SIP "Http digest authentication",or can use H.323 only.
In this case you would use an IP-to-IP GW.
Another use is transcoding.
