MPLS TE - IP Explicit Path
swaroop.potdar Mon, 07/16/2007 - 05:48
Both would work. If you have multiple links between 2 routers and want to force the link through a specific link you can probably use the interface ip.
If you want it to be choosen dynamically you can keep specifying the next-hop as the loopbacks of all the directly connected routers in the Tunnel path.
