Outbound Dialer & Import Rule
Jul 15th, 2007
I have a Outboudn Diler installed and every thing seems to be fine. The PG & Pim are active.
I am building a query and tryign toe import the phone numbers in tot eh database. For some reason, it does not look like it is importing anything.
Can some one giveme some directions.
ICM 6.0 with SR8
Overall Rating: 5 (1 ratings)
Igor1906 Mon, 07/16/2007 - 00:06
On the server where CampaignManager was installed see log files: c:\icm\[inst]\la\logfiles\, watch files [import_rule_file].err, in this file you can find all bad records while import.
ciscogini Mon, 07/16/2007 - 07:54
I do nto see this file the only logs realted to Outbound I see are
Gergely Szabo Mon, 07/16/2007 - 02:20
I am not sure whether it is supported to do such imports directly to the database tables. As far as I know, such imports are supported starting ICM 7.0.
ciscogini Tue, 07/17/2007 - 12:41
This one is working. it was he location of the file which was causing this.
