CCIe lab : influences of oral questions ?
Answered Question
Jul 16th, 2007
You pass the CCIE lab if you get 80 points. And each question is rated for X points.
The proctor may ask you questions, right ? I would like to know how the answers you give would influence the number of points you get for a question. Either you entered a configuration that meets the requirements or you did not enter a correct configuration. In the first case, you would get X points, in the second case, you should get 0 point. Or may be, if you make a "small mistake", the protcor may ask you a question, and if you give the correct anwer, you would get some points ?
I am trying to understand what to expect from these oral questions.
Any indication would be appreciated.
Navid
Correct Answer by tperrier about 9 years 8 months ago
There are no oral questions. On the other hand, you could ask the proctor some questions to help clarify a point. That has no influence on your score.
Overall Rating: 5 (1 ratings)
Correct Answer
tperrier Mon, 07/16/2007 - 02:28
  • Silver, 250 points or more
jgagznos Mon, 07/16/2007 - 13:16
Just confirming another post. There are no oral questions asked by the proctor. There is a CCIE assessor lab on cisco.com that will give you a decent idea of what to expect in the real lab.
HTH,
Joe
