HSRP and Traceroute question
Answered Question
Jul 16th, 2007
I have two ML Switches running as an HSRP failover pair.
I have a firewall with a static route to the networks served by the ML switches using the HSRP address.
When I traceroute from the firewall to one of the networks behind the ML switches, the traceroute shows the actual IP address of the switch it goes through rather than the HSRP address.
Its not a problem, but Im interested as to why I don't see the HSRP address in the traceroute.
Cheers,
Ben
Correct Answer by Jon Marshall about 9 years 9 months ago
Hi Ben
That is the way traceroute works. It reports the physical interface that it goes in on not the virtual address in use. So even though your firewall is referencing the HSRP address when it gets to the router it is the physical interface that reports back.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 07/16/2007 - 00:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Ben
Jon
