Reg:2960 48ttl
vasuramnet
Dear sir,
Iam having cisco catlyst 2960 48ttl switch in this i want to load HTML in this switch.because i want use this switch through webbrowser. but in this flash no html file plz tell me how can i load this html and its a folder.
One more help plz give me any lan and wan management tools.
srinivas.D
guruprasadr
Level 7
Level 7
HI Srinivas,
Pls refer link below for Http access:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12225fx/2960gsg.htm
CiscoWorks is the LAN & WAN Management Tools.If you are looking for Freeware you have several good monitoring tools:
1. MRTG
2. PRTG
Pls Rate if Helps
Best Regards,
Guru Prasad R
