Software upgrade with no ethernet
Answered Question
Jul 16th, 2007
I have a 3640 router with a 2FE2W-V2 but this module is not recognize by the router, due to it I want to make a upgrade software but
my procedure is I connect a cross-cable from the fast ethernet to my pc, so have you an idea how I can make the upgrade without ethernet connection?
Thanks in advance.
Correct Answer by mahmoodmkl about 9 years 7 months ago
Overall Rating: 4 (1 ratings)
shanemason Mon, 07/16/2007 - 05:54
If you have physical access to the router, change the speed of the console port to as fast as you can get (I've only been able to get up to about 115000), then once you've got that working, just issue a copy xmodem flash. I'd recommend hyperterminal for this as it has a good send feature.
HTH,
Shane
