Large Scale Dialout Using TACACS+
Jul 16th, 2007
I have big number of dialout connections . That why i am trying to use the concept of "Large Scale Dialout Using TACACS+". The problem that i have is that, in arround 800 situations i should dialout to standalone systems ( Windows PC's) that can be accessed remotly through an analog modem. All these systems have the same IP address. Can i use the concept of "Large Scale Dialout Using TACACS+" to send NAT Informations also, i.e, is it possible to send the Tel, nr. and routing informations an then the NAT command to translate the ip address in the dialer command which is not the real address of the end system to the real one.
Thanks for replaying
Ali
giaaaj Fri, 07/20/2007 - 12:47
Dharmesh thanks for replaying,
Do you mean we can change some attributes and be able to send a nat translation also . Can you please give me more details.
Thx
Ali
