ospf with ipsec between 2 asa. urgent
Jul 16th, 2007
hi all i am having problem configuring ospf wih ipsec between 2 asa.
i have followed he configuration example as it is on the cisco website. bu still the ospf neighbour doesn;t up on the outside. ipsec is working fine.
has anybody tried this before.
any help would be appreciated.
regards
sebastan
nchandy Mon, 07/16/2007 - 11:08
Hello Sebastan
Can you clarify:
You have a tunnel between 2-asa's terminating ipsec on outside interface and you would like to have ospf neighbors between the same outside interfaces of the ASA.this should be possible.can u send me the ospf and ipsec configs.
thanks
