Unity express license from 25 => 37 mailboxes : which code to order
Answered Question
Jul 16th, 2007
I am looking for the cisco product code to order 12 additional mailboxes on a Cisco Unity Express (CCM) system which has already 25 mailboxes.
Many Thanks
Dirk
Correct Answer by Rob Huffman about 10 years 1 week ago
Hi Dirk,
Sorry about that, I didn't read your post correctly. You are going to need the 50 mailbox part number;
SCUE-LIC-50CCM=
CUE only looks at the last License that was loaded, so these are not cumulative (as you correctly noted :)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 07/16/2007 - 05:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dirk,
Cisco Unified CallManager
12-mailbox package is:
SCUE-LIC-12CCM=
CME
SCUE-LIC-12CME=
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_installation_guide_chapter09186a0080677b06.html
Hope this helps!
Rob
dcharlier Mon, 07/16/2007 - 06:03
Hello Rob,
So you mean that it is supported that one can compose a package of different licenses :
?cue-vm-license_12mbx_ccm_2.3.x.pkg
?cue-vm-license_25mbx_ccm_2.3.x.pkg
25+12 = 37 ?
Dirk
Correct Answer
Rob Huffman Mon, 07/16/2007 - 06:23
  • Hall of Fame,
    Founding Member
Hi Dirk,
SCUE-LIC-50CCM=
Hope this helps!
Rob
