WCCP
Jul 16th, 2007
I have to configure WCCP on my Branch side so if user on LAN need access to specific sever X(base on our hub site)then request first go to Bluecoat box(type of proxy) on LAN, and then redirect the request to my Hub side serverX.all remainning traffic will flow normaly at spoke Branch offic.
Please help.
spremkumar Mon, 08/20/2007 - 21:03
hi
AFAIK i dont think you will be able to use WCCP for particular webpage/servers.
Better aggregate all traffic onto a L3 Switch wherein you can apply a policy specifying that the traffic destined to the intended servers to go via the proxy ( which you can setup as default gatway).
You can do the destination address matching using Access-lists matching the remote server ip address.
for the rest of the traffic it can make use of the normal routing in the L3 switch which could be your router to go out to the outside world.
regds
