MPLS and next-hop-self
mheusing Mon, 07/16/2007 - 04:52
Hi Lars,
In principle you would be right, IF the developers would not have been smart. If you configure it or not, a RR will not insert itself as next hop for any client. Makes a lot of sense (at least to the poor RRs ;-) In an MPLS environment, it really would break end-to-end LSPs and thus this single line of configuration could break your whole MPLS VPN BB. Once again, smart thing not to do it whatever the config says ;-)
Hope this helps!
Regards, Martin
Harold Ritter Mon, 07/16/2007 - 05:06
Lars,
next-hop-self never affects the reflected updates on the RR. It only affects updates received via eBGP if the RR is also configured for eBGP obviously.
Configuring next-hop-self on the RR is useful in an IPv4 context when your RR is also configured for eBGP. It doesn't apply to VPNv4 though as next-hop-self is the default behavior for routes injected in VPNv4.
Hope this helps,
