Callmanager IVR
Jul 16th, 2007
Hi there,
I`ve been told that callmanager ver 5.1 features an inbuilt IVR? Is this correct?
I have a requirement for callers to dial a main number then be given options to contact a receptionist or department or dial a internal number etc...
Hope you can help
Overall Rating: 5 (2 ratings)
lpezj Mon, 07/16/2007 - 03:52
I don't think so. You will need to add for that purpouse Cisco IP/IVR or, for a bigger deployment, CVP.
Hope this helps,
Juan Luis
norm.trees Mon, 07/16/2007 - 04:30
Hi thanks for the reply,
can you integrate call manager with an IVR server only, or will an ICM server need to be implemented & integrated too.
lpezj Mon, 07/16/2007 - 04:38
You can integrate CallManager with Cisco IP/IVR without ICM, in the same way as if you used IPCC Express.
Hope this helps,
Juan Luis
(Please, rate helpful posts ;-))
