BAT file format
Jul 16th, 2007
hello expert,
I have call manager 4.2 and i have a new field on the directory number of UserDeviceProfile, the new fields is "Forward Unregistered Internal" and "Forward Unregistered External".
I use the BAT file to create UserDEviceProfile and i need to use this new field "Forward Unregistered Internal". when i trid to create Bat file format i cannot found this field.
i had just "Forward No Coverage Internal" Forward No Coverage External" Forward No Answer External"
I dont know if is exist a new Bat for call Manager 4.2 to use this field.
thank you in advance.
Overall Rating: 4 (1 ratings)
rob.huffman Mon, 07/16/2007 - 06:58
Hi Jose,
I don't lnow why Cisco doesn't use the same wording, but these are the same thing :)
Forward Unregistered Internal = Forward No Coverage Internal
Forward Unregistered External = Forward No Coverage External
Try out a test BAT using these fields and you will see the proper config is actually setup.
Hope this helps!
