IDS 4215 - Multiple Data Bypasses
Jul 16th, 2007
My usually quiet IDS logs had a number of consecutive "error:warning - inline data bypass has started" messages this morning.
Everything appears to be normal. The only time I have seen this in the past is when the unit is booted. It is plugged into a power supply, so I do not think it lost power.
Is there anything in particular I should check beyond that? I am not terribly knowledgable in this area. I suppose I could disable bypassing.
