Installing Patch on IPCC Express
Jul 16th, 2007
We are currently using IPCC Express 4.0(4)_Build140. We are planning to install patch CRS 4.0(4)SR1 on IPCC Express. To install this is it necessary to have BARS installed on the IPCC Express server?????
Can some one let me know the procedure to install the patch!!!!
We are having only one IPCC express server which is connected to CCM cluster.
Please help me out!!!!
Overall Rating: 4 (1 ratings)
Loading. Mon, 07/16/2007 - 06:53
Thanks for your info.
I need some clarification that
1.Is it we need to Configure BARS on CCM Publisher Database??
2. Is it we need to store the patch file on Publisher?
3. In Restore wizard: Step 2 of 4
- In the "Data Destination Server" field, wheather we need to enter Publisher IP Address or IPCC express server IP Address ?
Please guide me !!!!!!!
Because i am not very much familiar with installing patches!!
Brandon Buffin Mon, 07/16/2007 - 07:11
1. Yes, install BARS on the publisher.
2. You will need a copy of the patch file on the BARS backup server (publisher) and on the IPCC Express server.
3. This is unclear in the instructions, but you will enter the IPCC Express Server IP address.
Hope this helps.
Brandon Wed, 07/25/2007 - 04:15
Hi Brandon,
Thanks alot for your valuable answers.
Just we are very much worried about database.Because we don't have redundancy for existing IPCC Express server.
After taking the backup of CRS engine, if we install the patch(SR1),but after installing the patch if the existing database lost, if then we tried to restore from the backup, if it does't work...then it becomes a big problem.
So please advise us regarding,
What are the backup we need to take?
What are the standard procedure & restore procedure for this Patch installation we need to look?
Can it possible to take GHOST image of the existing IPCC Express server?
Can we take the image of the IPCC Express on rented Cisco server so that if something goes wrong,we can revert back from rented server?
Please advise us!!!!!!
Thanks & Regards,
Krishna Thu, 07/26/2007 - 01:57
Hi Brandon,
If i am not wrong MCS7845 is configured with RAID, so we cannot make the Ghost image.
Can you please suggest which are the options we can see for full backup.
Thanks & Regards,
Krishna Thu, 07/26/2007 - 06:14
Hi Brandon,
I am having a query below; Please let me know is it technically possible or not !!
MCS7845 has 4 harddisks(2:2);If we remove the backup hard disks before installing the patch& do the patch installation on active drives. After the patch installation if something goes wrong we can put the backup drives to restore the Configuration and Database!!!!
