3750 Port Security Question?
Answered Question
Jul 16th, 2007
Someone enabled port security on a 3750 switch that we need to disable. Is there a global configuration command that I can use instead of trying to disable it manually on 48 ports? any other recommendations will be appreciated.. Thanks,
Correct Answer by Jon Marshall about 9 years 6 months ago
Could you not just do
switch(conf t)# int range fa0/1 - 48
if gig ports gi0/1 - 48
switch(config-if-range)# no switchport port-security
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 07/16/2007 - 05:41
Jon
Amit Singh Mon, 07/16/2007 - 05:54
Agree with Jon, just use " interface range" command and disable the port-security on all the interface :
conf t
interface range gig 1/0/1 - 48
HTH,
-amit singh
johnny-diaz Mon, 07/16/2007 - 09:47
Awesome.. Thanks guys. 1 last thing to confirm. We have STP port fast enabled on that switch.. does removing port security cause problems with this or should I also disable Port Fast. Thanks for your help on this 3750.
