How to make Multiple VPNs over one E1 between PE and CE?
Jul 16th, 2007
Hi ALL!
Сommon scheme:
PE--E1--CE(with 2-5 VRFs)--E1--C_router(with 2-5 VRFs)
I know 2 main solutions for subject:
1. GRE tunnels over E1 between PE-CE-C_router
2. Frame relay over E1 between PE-CE-C_router (IMHO MultiVRF-VRF-lite is FR approach)
What most preferred solution from the point of view of Cisco and why ?
Is it possible another solutions?
swaroop.potdar Mon, 07/16/2007 - 07:31
  • Blue, 1500 points or more
It would be recommended to use subif in place of GRE.
Some reasons i can think offhand would be:
1) Higher overhead of GRE compared to FR (24 vs 6)
2) No possibility of shaping of policing with GRE which could be required in your specific topology.
HTH-Cheers,
Swaroop
swaroop.potdar Tue, 07/17/2007 - 12:56
Yes you are right with the info you found.
Looking at the document policing and shaping is indeed supported with GRE.
You can although decide to go with FR and subif based on the overheads.
HTH-Cheers,
Swaroop
