bgp announce route
Jul 16th, 2007
we would like to announce routes to provider A and B. detail please refer following.
for provider A
200.1.0.0/23
200.1.2.0/24
200.1.3.0/24
for provider B
200.1.0.0/24
200.1.1.0/24
200.1.2.0/24
200.1.3.0/24
We find that, we always anounce 4 routes to provider A. what wrong is it? please advice.
Best regards
router bgp 30x
neighbor 202.1.1.1 route-map Set_ASN_PA out
access-list 45 permit 200.1.0.0 0.0.1.255
access-list 55 permit 200.1.2.0 0.0.0.255
access-list 55 permit 200.1.3.0 0.0.0.255
ip as-path access-list 300 deny .*
ip as-path access-list 300 permit ^$
route-map Set_ASN_PA permit 10
match ip address 45
set as-path prepend 30x
route-map Set_ASN_PA permit 20
match ip address 55
route-map Set_ASN_PA permit 30
match as-path 300
Overall Rating: 4.9 (10 ratings)
Harold Ritter Mon, 07/16/2007 - 07:27
  • Cisco Employee,
ACL 45 allows 200.1.0.0/24 and 200.1.1.0/24 because of the wildcard mask 0.0.1.255. This is why provider A received the 4 routes.
Hope this helps,
leungcm Mon, 07/16/2007 - 07:30
hi,
how do we force it to /23? pls advise
best regards
Harold Ritter Mon, 07/16/2007 - 07:49
  • Cisco Employee,
Prior to announcing the /23 to your SP, you first need to inject the /23 into BGP a network statement and a static route to null0 as follow:
router bgp x
network 2000.1.0.0 mask 255.255.254.0
ip route 200.1.0.0 255.255.254.0 null0
Also, if you want to only allow the /23 (200.1.0.0/23) towards provider A and not the two /24s (200.1.0.0/24 and 200.1.1.0/24), you should use a prefix-list or an extended ACL instead of the standard ACL.
ip prefix-list test permit 200.1.0.0/23
Hope this helps,
leungcm Mon, 07/16/2007 - 07:59
Dear Hritter,
Thanks. We would like to use extended ACL to announce /23. Is it
access list 101 permit ip 200.1.0.0 0.0.1.255 255.255.254.0 0.0.0.0.
pls advise
Harold Ritter Mon, 07/16/2007 - 08:02
  • Cisco Employee,
Your ACL would work but I would rather configure it as follow:
access list 101 permit ip 200.1.0.0 0.0.0.0 255.255.254.0 0.0.0.0.
Hope this helps,
leungcm Mon, 07/16/2007 - 08:39
We add the access but it displays as:
access-list 101 permit ip host 200.1.0.0 host 255.255.254.0
when I re-start the bgp, it does not announce 200.1.0.0/23 out but it announce 200.1.2.0/24, 200.1.3.0/24. It means that it announce two routes only. Any idea?
Best regards
Harold Ritter Mon, 07/16/2007 - 08:56
  • Cisco Employee,
It is normal behavior for the ACL to display as host as this means perfect match (or match all bits).
Can you post the new route-map and ACL and
the output of a "show ip bgp route-map Set_ASN_PA"
leungcm Mon, 07/16/2007 - 09:20
config is following:
access-list 145 permit ip 203.x.2.0 0.0.0.0 255.255.254.0 0.0.0.0
access-list 55 permit 203.x.0.0 0.0.0.255
access-list 55 permit 203.x.1.0 0.0.0.255
match ip address 145
match ip address 55
match as-path 200
BGP table version is 17687614, local router ID is 202.x.x.xx
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 203.x.0.0 203.x.y.94 0 32768 i
*> 203.x.1.0 0.0.0.0 0 32768 i
*> 203.x.2.0 203.x.y.95 0 32768 i
*> 203.x.3.0 0.0.0.0 0 32768 i
Harold Ritter Mon, 07/16/2007 - 09:29
  • Cisco Employee,
Did you generate the /23 using a network statement as I recommended previously? Can you post a "show ip bgp 203.x.2.0 255.255.254.0"
Also, note that the instance 30 in your routemap will allow everything that hasn't been allowed by the two previous instances.
leungcm Mon, 07/16/2007 - 09:38
hi,
do we use
match as-path 300
Harold Ritter Mon, 07/16/2007 - 09:41
  • Cisco Employee,
Sorry. I meant to say everything that matches the as-path. Is 203.*.2.0/23 present in the BGP table?
leungcm Mon, 07/16/2007 - 09:49
hi,
we check it, the result is
% Network not in table
it is because the network is inside our network
best regards
Harold Ritter Mon, 07/16/2007 - 09:52
  • Cisco Employee,
Did you use a network statement to generate 203.x.2.0/23 and also did you configure a matching route to null0?
leungcm Mon, 07/16/2007 - 09:56
hi,
the network statement is /24, total 4 network statement there.
Do I change it to /23 and two /24?
If so, do it affect the provider B? please advise
Best regards
Harold Ritter Mon, 07/16/2007 - 10:06
  • Cisco Employee,
You definitely need to have a network statement for the /23. You also need the two netwrok statements for the /24s as you still need to advertise them to your other provider.
I looked at instance 30 of the route-map and the as-path list is actually inverted:
The first line denies everything as the second one only allows the locally originated prefixes but will ever be used.
leungcm Mon, 07/16/2007 - 10:37
we put network statement on bgp router
network 203.x.0.0
network 203.x.1.0
network 203.x.2.0 mask 255.255.254.0
after that, we cannot announce 203.x.2.0/23 route to both provider A and B. So, we fall back to existing.
any idea?
Best regards
Harold Ritter Mon, 07/16/2007 - 11:00
  • Cisco Employee,
Do you mean that a) route 203.x.2.0/23 was still not announced via BGP or b) that it was announced to both providers?
If a) then you need to make sure you have a route in the RIB for the /23. You can had a static route as follow:
ip route 203.x.2.0 255.255.254.0 null0
If b) you need to change the route-map towards provider B to filter the /23 out.
leungcm Wed, 07/18/2007 - 05:45
hritter,
we re-config the bgp and we would like to have as following:
for provider A
200.1.0.0/24
200.1.1.0/24
200.1.2.0/23
for provider B
200.1.0.0/24
200.1.1.0/24
200.1.2.0/24
200.1.3.0/24
we find that the router always announces /23 to provider B. How do we send four routes? pls advice
router bgp 30x
network
200.1.0.0
200.1.1.0
200.1.2.0 mask 255.255.254.0
neighbor 202.1.1.1 route-map Set_ASN_PB out
ip route 200.1.2.0 mask 255.255.254.0 null0 250
access-list 20 permit 200.1.0.0 0.0.0.255
access-list 20 permit 200.1.1.0 0.0.0.255
access-list 20 permit 200.1.2.0 0.0.0.255
access-list 20 permit 200.1.3.0 0.0.0.255
ip as-path access-list 130 deny .*
ip as-path access-list 130 permit ^$
route-map Set_ASN_PB permit 10
match ip address 20
route-map Set_ASN_PB permit 30
match as-path 130
BGP table version is 248, local router ID is 10.254.210.1
*> 200.1.0.0 0.0.0.0 0 32768 i
*> 200.1.1.0 0.0.0.0 0 32768 i
*> 200.1.2.0/23 0.0.0.0 0 32768 i
Harold Ritter Wed, 07/18/2007 - 06:16
  • Cisco Employee,
You need to change the ACL for the route-map towards provider B. You need to use an extended ACL there as well to achieve what you want.
Here's a sample config that would do what you want.
router bgp x
network 200.1.0.0
network 200.1.1.0
network 200.1.2.0
network 200.1.2.0 mask 255.255.254.0
network 200.1.3.0
ip route 200.1.0.0 255.255.255.0 null0 250
ip route 200.1.1.0 255.255.255.0 null0 250
ip route 200.1.2.0 255.255.255.0 null0 250
ip route 200.1.2.0 255.255.254.0 null0 250
ip route 200.1.3.0 255.255.255.0 null0 250
match ip address 110
match ip address 120
access-list 110 permit ip host 200.1.0.0 host 255.255.255.0
access-list 110 permit ip host 200.1.1.0 host 255.255.255.0
access-list 110 permit ip host 200.1.2.0 host 255.255.254.0
access-list 120 permit ip host 200.1.0.0 host 255.255.255.0
access-list 120 permit ip host 200.1.1.0 host 255.255.255.0
access-list 120 permit ip host 200.1.2.0 host 255.255.255.0
access-list 120 permit ip host 200.1.3.0 host 255.255.255.0
Hope this helps,
