Traceroute o/p on cisco router
Answered Question
Jul 16th, 2007
When I traceroute to a destination ip address in the network from the router, the last hop to reach the destination has one timed out problem as below
router#traceroute <dest-ip> address
Tracing the route to <dest-ip> address
1 <next-hop> 4 msec * 0 msec
I am just curious and would like to understand the reason for the 2nd probe getting timed out. I am not finding bad links and so wondering why that probe should be dropped. This characteristics, I am seeing in most of the networks and its particularly for the last hop when traced from the router.
Anantha Subramanian Natarajan
Correct Answer by Richard Burts about 9 years 8 months ago
Anantha
I believe that the difference is that the response from the intermediate hop is not destination unreachable but is Time To Live Expired. The IOS does not throttle these messages like it does the destination unreachable messages.
Rick
Overall Rating: 4.8 (3 ratings)
anasubra_2 Mon, 07/16/2007 - 12:27
Thank you very much and its really good to know .............
But I am just curious how the intermediate hop doesn't get timed out as below
router#traceroute
1 < first-hop> 12 msec 12 msec 16 msec
2 < second-hop> 12 msec * 12 msec
Is that something I am missing .....
Once again, thanks for this answer.
Correct Answer
Richard Burts Mon, 07/16/2007 - 12:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Anantha
Rick
Harold Ritter Mon, 07/16/2007 - 15:42
  • Cisco Employee,
Rick,
As always, you are absolutely correct.
Richard Burts Mon, 07/16/2007 - 18:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Harold
Thanks for the confirmation.
Rick
anasubra_2 Tue, 07/17/2007 - 08:32
Hi Rick,
Got it, Thank you very much ...
Richard Burts Tue, 07/17/2007 - 10:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Anantha
I am glad that we were able to help you resolve your questions. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read an answer that did resolve the question. I encourage you to continue your participation in the forum.
Rick
anasubra_2 Tue, 07/17/2007 - 14:03
Hi Rick,
You people deserve the rating and I always liked this forum because it gives me answers :) ..I mean understandable answers.
Once again thanks and bye
rakesh.shah Tue, 07/17/2007 - 10:57
Rick,
my 2 cents-
There could be one more reason for this behaviour - the intermideate nodes has to make only routing/switching function, while the destination node has to reply to the service (in this case icmp/trace). ping/tracert are categorised as low priority by default. So depending upon the free/busy status of end node, the destination node may able to reply tracert request in timely manner or may not.
regards
Rakesh
Richard Burts Tue, 07/17/2007 - 11:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rakesh
Actually when each intermediate node receives the traceroute probe packet, decrements the TTL, and if it gets to zero, then they must discard the packet and they must generate the ICMP error message about time exceeded. So each intermediate node must generate error messages similar to the error generated by the destination router. So the processing load is pretty much the same in the intermediate nodes as it is in the destination.
Rick
