eBGP with loopback address issue
Answered Question
Jul 16th, 2007
Hi Sir,
The following two routers (R6 & R9) are configured to form an eBGP connection:
R6
interface Serial0/0
description *** Connection to R9 ***
ip address 150.50.69.1 255.255.255.252
router bgp 600
neighbor 150.50.9.99 remote-as 900
neighbor 150.50.9.99 ebgp-multihop 3
address-family ipv4
neighbor 150.50.9.99 activate
no auto-summary
no synchronization
exit-address-family
ip route 150.50.9.0 255.255.255.128 150.50.69.2
R9
interface Loopback0
ip address 150.50.9.99 255.255.255.255
interface Serial0/0
description *** Connection to R6 ***
ip address 150.50.69.2 255.255.255.252
router bgp 900
neighbor 150.50.69.1 remote-as 600
address-family ipv4
neighbor 150.50.69.1 activate
no auto-summary
no synchronization
exit-address-family
From the config, it looks like the eBGP connection won't come up because the command "neighbor 150.50.69.1 update-source lo0" is missing on R9. Surprisingly, the connection did come up, as follows:
R6#sh ip bgp ne 150.50.9.99
BGP neighbor is 150.50.9.99, remote AS 900, external link
BGP version 4, remote router ID 150.50.9.99
BGP state = Established, up for 01:20:08
<---Output omitted--->
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled
Local host: 150.50.69.1, Local port: 50619
Foreign host: 150.50.9.99, Foreign port: 179
R9#sh ip bgp nei 150.50.69.1
BGP neighbor is 150.50.69.1, remote AS 600, external link
BGP version 4, remote router ID 150.50.6.6
BGP state = Established, up for 01:13:56
Local host: 150.50.9.99, Local port: 179
Foreign host: 150.50.69.1, Foreign port: 50619
Please advise. I'm a little confused.
Thank you.
B.Rgds,
Lim TS
Correct Answer by Harold Ritter about 9 years 11 months ago
It is indeed a good practice to configure both ends properly so they can both actively initiate the BGP session.
Hope this helps,
Overall Rating: 5 (4 ratings)
Harold Ritter Mon, 07/16/2007 - 09:50
  • Cisco Employee,
This will work as long as one side is configured correctly.
This is because R6 actively opened the TCP session using 150.50.9.99 as its destination. R9 passively opened the session using TCP syn destination address (150.50.9.9).
Note, that it would not work if R9 was to actively open the connection.
Hope this helps,
limtohsoon Mon, 07/16/2007 - 15:34
Hi Harold,
Yup, I can see R6 (active open) and R9 (passive open), as follows:
<---Output omitted --->
SRTT: 300 ms, RTTO: 303 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 8 ms, maxRTT: 300 ms, ACK hold: 200 ms
Flags: active open, nagle
IP Precedence value : 6
R9#sh ip bgp ne 150.50.69.1
Flags: passive open, nagle, gen tcbs
Is it a good practice to configure both ends of the BGP session correctly? I always do so. The sample config in this post is something I came across in a technical book.
Thank you.
B.Rgds,
Lim TS
Correct Answer
Harold Ritter Mon, 07/16/2007 - 15:39
  • Cisco Employee,
Hope this helps,
