thisisshanky Mon, 07/16/2007 - 10:27
  • Purple, 4500 points or more
Just look at the Enterprise parameters webpage and you can see all the URLs.
Warren Swingle Thu, 12/06/2007 - 19:59
Did you ever find the URL's for speed and fast dials? I'm trying to find them on a CM 6.0 system, no luck.....
Rob Huffman Fri, 12/07/2007 - 06:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Warren,
Sadly the method used to access PAB/Fastdials changed with the release of CCM 5.x. Rather than using URL's like in the 3.x and 4.x CCM Trains these are now accessable via the Personal Directory (Option 4) under the Directories Button. You probably won't love this change, like many others here as these are now username/pin protected and very cumbersome for users to actually use :(
Hope this helps!
Rob
