probe script failed at csm
Jul 16th, 2007
Hi Everyone,
This is my first time to use script for probe at csm. The following is my configuration ,script and the sh tech script output. we fail before "set sock [socket $ip $port]".
The last exit status = 4001 and last errorCode = 65534. Can anyone help me to find why we failed with the script? Thanks in advance.
Jason
CSM configuration:
vlan 876 server
description *** UNIX APP-SERVER TRAFFIC VLAN ***
ip address 172.24.176.4 255.255.248.0 alt 172.24.176.5 255.255.248.0
alias 172.24.176.6 255.255.248.0
route 172.24.62.0 255.255.255.0 gateway 172.24.176.1
script file tftp://172.24.62.126/xxsping.tcl
probe XX1script script
script XX1script
interval 30
retries 3
failed 60
open 15
serverfarm tdc-xx1tst-01
nat server
nat client DEV-PAYMTWG
real 172.24.62.12
ins
probe XX1script
vserver tdc-xx1tst-01
virtual 172.24.173.62 tcp 8810
replicate csrp connection
persistent rebalance
inservice
script:
#!name = XX1script
# XX/1 Ping
## Request ##
set ip $csm_env(realIP)
set port $csm_env(realPort)
# XX/1 TC
set xtcu "rfdev"
set xtcp "7q4Njdfl"
set EXIT_MSG "SOAP req"
# SOAP Request
set req "POST http://$ip:$port/xxs HTTP/1.0\n"
append req "Accept: text/xml\n"
append req "Accept: multipart/*\n"
append req "Content-Length: 668\n"
append req "Content-Type: text/xml; charset=utf-8\n"
append req "SOAPAction: \"xxs#Transaction\"\n"
append req "\n"
append req "<xml version=\"1.0\" encoding=\"UTF-8\"?>\n"
append req "<SOAP-ENV:Envelope xmlns:SOAP-ENC=\"http://schemas.xmlsoap.org/soap/encoding/\"\n"
append req "SOAP-ENV:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"\n"
append req "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"\n"
append req "xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\"\n"
append req "xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">\n"
append req "<SOAP-ENV:Header><t:Transaction xmlns:t=\"xxs\">\n"
append req "<tc>\n<iden u=\"$xtcu\" p=\"$xtcp\"/>\n<provider>Loyalty</provider><trace>ed</trace>\n</tc>\n"
append req "</t:Transaction></SOAP-ENV:Header><SOAP-ENV:Body><ns1:XXTransaction xmlns:ns1=\"xxs\">\n"
append req "<REQ><PingRQ><Text>LoyaltyPingTest</Text></PingRQ></REQ>\n"
append req "</ns1:XXTransaction></SOAP-ENV:Body></SOAP-ENV:Envelope>\n"
# open a socket
set EXIT_MSG "open socket 1 $ip $port"
set EXIT_MSG "open socket 2"
fconfigure $sock -buffering none -eofchar {}
#puts "req:\n$req"
# send request
set EXIT_MSG "send req: $ip $port"
puts -nonewline $sock $req;
#puts "wait"
# Wait for response
set EXIT_MSG "read resp"
set line [ read $sock ]
# close the socket
#puts "close"
set EXIT_MSG "close"
close $sock
if { [ regexp "HTTP/1.. (\[0-9\]+) " $line match status ] } {
puts "real $ip server response : $status"
if { [ regexp ".*<PingRS><Text>(.+)</Text>" $line match prs ] } {
puts "pingrs: $prs"
if { $status == 200 && $prs == "LoyaltyPingTest" } {
puts "exit 5000"
exit 5000
} else {
puts "exit 5001"
exit 5001
#puts "response $line\n"
csco10046fen Mon, 07/16/2007 - 11:39
sorry, I forgot the Sh tech script as following:
Software version: 4.2(3a)
SCRIPT BUFFER STATS
:SCRIPT BUF(0xbc74620): scriptname XX1script from file (16386) tftp://172.24.62.126/xxsping.tcl
Last load time = MON JUL 16 18:32:47 2007
flag (0x1) ref (0)
tclbuf: curr_index (1)
tclbuf: index(0) ref(12) buf(0xbc73540) len(1963)
tclbuf: index(1) ref(0) buf(0xbc71fe8) len(2142)
tclbuf: index(2) ref(0) buf(0x0) len(0)
tclbuf: index(3) ref(0) buf(0x0) len(0)
SCRIPT SUBSYSTEM STATS
SCRIPT SUBSYTEM STATS
Total number of Active scripts: 1
runs = 154 +4
resets = 154 +4
SCPOST:
send = 0 +0
send err = 0 +0
recv = 0 +0
recv err = 0 +0
#killed = 146 +4
#task spawn err = 0 +0 Errno(0x0)
#paniced = 0 +0
exception = 0 +0
exception task id = 0x0 and sc = 0x0
#rst run mismatch= 0 +0
#sc not released = 0 +0
#sc double end = 0 +0
#sc abort del notify = 0 +0
sc acquring sc_cntrl_mu = 0x0
sc stuck on free = 0x0
sc not rel = 0x0
sc doubel end = 0x0
SCRIPT CONTROLLER STATS
SCRIPT(0xbc51350) stat blk(0xbc513b8): TCL_XX1scriptbc51350
CMDLINE ARGUMENT:
curr_id 1 argc 0 flag 0x0::
type = PROBE
task_id = 0x0: run_id = 512 ref count = 2
task_status = TASK_DONE run status = OK
start time = MON JUL 16 19:16:06 2007
end time = MON JUL 16 19:16:35 2007
runs = 154 +4
resets = 154 +4
notrel = 0 +0
buf read err = 0 +0
killed = 146 +4
panicd = 0 +0
last exit status= 4001 last Bad status = 4001
Exit status history:
Status (SCRIPT_KILLED) occured #(145) last@ MON JUL 16 19:16:35 2007
**TCL Controller:
tcl cntrl flag = 0x7fffffff
#select(0) close_n_exit(1) num_sock(1)
MEM TRACK last alloc(0) last size(0) alloc(0) size(0)
hm_ver (5) flag(0x0) script buf(0xbc74620) new script buf(0x0)
lock owner(0x0) sig taskdel:0 del:0 syscall:0 syslock:0 sig_select
script ptr (0xbc71fe8) id(1)
Config(0xbc44e30) probe -> 172.24.62.12:8810
tclGlob(0xbc70908)
SCRIPT RESOURCE(0xbc72c08)-------
#Selects(0) Close_n_exit(1) #Socket(1)
OPEN SOCKETS:
Persistent Variables
Last erroInfo =
Last errorCode = 65534
Last panicInfo =
EXIT_MSG = open socket 1 172.24.62.12 8810
