Scripts on ACS 4.1 SE
Jul 16th, 2007
A couple of questiosn for you all:
1. On the ACS 1113 SE appliance, hwo does one utilize the CSUtil function?
2. Can you do any file sharing since these are Windows servers? If so, how do you share the bin directory?
3. Has anyone tried to run their old scripts on the new servers to accomplish tasks? If so, can you share how you did it?
DWane
Overall Rating: 5 (1 ratings)
rochopra Mon, 07/16/2007 - 15:55
All the questions you have asked need to configure Appliance as ACS for windows.
Why have you not preffered buying ACS for windows instead, that would have also saved you $4000.
ACS appliance is optimised to run ACS services, any changes in the default functioning will definately impact performance.
Rohit
