CCM 4.1/ Route Group not showing my SIP trunk as an option
Answered Question
Jul 16th, 2007
I am trying to setup a route group that will use both a SIP trunk and an ICT. Basically if the SIP trunk is down or not receiving connections, I would like the call to route to the ICT. The only problem is that when I create the Route Group, it does not show my SIP trunk as an available device to choose from. Is this standard? How can I add it?
Correct Answer by Brandon Buffin about 10 years 1 week ago
Sounds like your SIP trunk is being used in a route pattern. If it is used in a route pattern, it is no longer available to be added to a route group and vice versa.
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (3 ratings)
Correct Answer
Brandon Buffin Mon, 07/16/2007 - 12:55
  • Purple, 4500 points or more
Brandon
