ACS v3.2
Jul 16th, 2007
Hello there,
I have a question for ACS v3.2 - Does anyone know if ACS has to keep the session between ACS and Windows Database open for wireless users authentications? A little history on the problem: I have a wireless LAN using ACS v3.2 and on ACS I have defined a Windows Database to be used for unknown users (which are the 99% of wireless users) A lot of users are being prompted to re-authenticate every so often. I'm trying to troubleshoot this issue. Thank you very much fro your help in advance....
rochopra Mon, 07/16/2007 - 16:03
On AP try changing EAP reauthentication interval.
Also checking Fast Reconnect on ACS and wireless client will help.
Rohit
