internet access
Jul 16th, 2007
hi,
this: my config
interface MFR1
mtu 4470
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
encapsulation frame-relay IETF
no ip route-cache cef
ip route-cache flow
no ip mroute-cache
load-interval 30
no arp frame-relay
frame-relay multilink bid xxxxxxx
frame-relay lmi-type ansi
interface MFR1.500 point-to-point
ip address x.x.X.x x.X.x.X
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
no cdp enable
no arp frame-relay
frame-relay interface-dlci 500 IETF
interface FastEthernet0/0
description xxxxxxx
bandwidth 100000
ip address x.x.x.x x.x.X.x
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip route-cache flow
load-interval 30
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
mtu 4470
bandwidth 1536
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
encapsulation frame-relay MFR1
ip route-cache flow
load-interval 30
no arp frame-relay
interface Serial0/2/0
mtu 4470
bandwidth 1536
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
load-interval 30
no arp frame-relay
sh ver :
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.3(11)T3, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 26-Jan-05 02:49 by pwade
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(3a), RELEASE SOFTWARE (fc2)
XXXXX uptime is 1 hour, 12 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.123-11.T3.bin"
Cisco 2811 (revision 53.51) with 223232K/38912K bytes of memory.
Processor board ID FTX0950C5AC
2 FastEthernet interfaces
2 Serial interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
I need to limit the 2XT1 (3Mbit) to 70% of it's bandwidth, how can i do it?
and i want that 1 station will get the highest priority when using the internet.?
how can i implement this?
If you want to limit the PVC speed and employ some QoS do the following.
1. enable frame-relay traffic shaping on the MFR interface (not the subinterface)
2. Define a class-map to match the desired traffic needs priority
class-map match-any
match access-group
3. Create the acl to define the traffic
4. Create a policy map where you can define how the given class should behave
policy-map
class ce_vpn_6600003_l2l
bandwidth
5. Create a map-class where you can define FR parameters for the PVC
map-class frame-relay
frame-relay cir 2150000
frame-relay bc 21500
frame-relay mincir 2150000
service-policy output
6. Assign the class to the MFR subinterface
traffic which not defined will fall to the default class.
class
You have quite lot options under the policy map (set dscp, RED, WRED) so better to browse Cisco web for more info. The above is to configure CBWQ, but if you have some voip traffic which needs priority better to use LLQ.
Hope it helps,
Krisztian
lepavelcisco Tue, 07/17/2007 - 04:12
hi,
is this reffered to in going or out going traffic? how do i indecate outgoing traffic?
now how can i do:
1. give higtest priority to 2 specipic ip address?
2.how can i limit specipic protocol trafic to specific bandwith let say 80 Kbps?
3. how can i limit session or per user traffic to let say 20 kbps per user or session or connection?
The direction is definied under the class-map.
service-policy output/input
1. What kind of traffic you want to give priority? Is it UDP based or TCP?
If UDP (for instance RTP) is being used then the LLQ is the best if TCP the CBWQ is suitable.
For defining the "interesting" traffic use acl. For example to give 80 kbps for telnet traffic from host 192.168.100.10 to any destination:
access-list 111 permit tcp host 192.168.100.10 any eq 21
class-map match-any telnet
match access-group 111
policy-map outbound
class telnet
bandwidth 80
2. You can define multiple classes using class map and define different behavior for each under the policy-map.
3. I think this can not be configured rather it should be configured on the server (for example ftp servers are able to limit the traffic per session and number of simultaneous sessions)
Hope it helps, rate if does
Krisztian
