Dial In Solutions Requirements
Jul 16th, 2007
Hi. I would like to setup a remote router where clients can dial in using their 56k modem. I've read that for this scenario, one would require network module digital modems and network module ISDN BRI. Cisco has announced EoL/EoS for NM digital modems and suggested to replace with PVDM s, but it seems that PVDM-DM only supports PRI and not BRI. Is this correct? Is there any other alternative dial in solutions which is more feasible?
Thanks in advance
paolo bevilacqua Tue, 07/17/2007 - 02:36
  • Hall of Fame,
    Founding Member
How many ports you need? If few, get the BRI equipment you need, even if used, and it ends there.
If more ports or have to grow, then get PRI, the best choice would be an as5xxx,even used if the new ones are too expensive.
fahmyaziz Tue, 07/17/2007 - 04:30
I'm only catering for about 10 users (not simultaneously) I was thinking of getting a 4 port NM 4B-ST. Its just that after reading the data sheet, Cisco did not mention about supporting BRI cards with the new PVDM digital modems and said only PRI. Have you tried using the PVDM digital modems with NM BRI cards?
paolo bevilacqua Tue, 07/17/2007 - 14:13
  • Hall of Fame,
    Founding Member
I have not tried, but I have no reason to believe that it may work, because the datasheet clearly states that the PVDM-xxDM only works in conjunction with the NM PRI modules.
hope this helps, please rate post if it does!
