Stacked 3750 question
Jul 16th, 2007
We have a 3750 that is stacked. Stack 2 and 3 is running on RPS but stack 1 is fine. Is there a way we can reload just stack 2 and 3?
nj40ki01xds02#show env stack
SWITCH: 1
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is AVAILABLE
SWITCH: 2
FAN is OK
TEMPERATURE is OK
POWER is FAULTY
RPS is SUPPLYING
SWITCH: 3
FAN is OK
TEMPERATURE is OK
POWER is FAULTY
RPS is SUPPLYING
Overall Rating: 5 (1 ratings)
Aaron Harrison Tue, 07/17/2007 - 00:39
  • Community Spotlight Award,
    Member's Choice, May 2015
Use the reload command, but put the stack member number after it:
reload slot 2
reload slot 3
Aaron
Please rate helpful posts...
Pavel Bykov Tue, 07/17/2007 - 02:45
  • Silver, 250 points or more
Alternatively, you can logon to the certain switch in a stack using "session X" command, where X is a switch number in a stack. You can see which is which using "show switch command"
#sh switch
Current
Switch# Role Mac Address Priority State
*1 Master 000f.f762.a400 8 Ready
2 Slave 0012.01f9.af80 1 Ready
