removing the configuration asa5520
Jul 16th, 2007
I want to put the asa5520 to the factory defoult please let me know how to do that. how to remove the configuration file from it.
please help me i am not able to do that. Thanks.
I`m not sure you can push this back to the factory default, however to completely remove the configuration, do the following:
Enable,
Conf t
write erase
Confirm the erase, and then reload the device via reload (do not save the configuration).
If the device has a CSC-SSM module, then theres a reset factory defaults on the menus of the module (type Session 1 from the ASA)
Fabio Robson Leandro Fri, 12/14/2012 - 18:11
After do this procedure my ASA 5520 loose any thing and it´s not avaliable the option nameif and ip address in all interfaces.
I just have this option to set up in all interfaces:
ASA01(config)# interface gigabitEthernet 0/0
ASA01(config-if)# ?
Interface configuration commands:
  default      Set a command to its defaults
  description  Interface specific description
  dhcp         Configure parameters for DHCP client
  duplex       Configure duplex operation
  exit         Exit from interface configuration mode
  flowcontrol  Configure flowcontrol operation
  help         Interactive help for interface subcommands
  no           Negate a command or set its defaults
  shutdown     Shutdown the selected interface
  speed        Configure speed operation
ASA01(config-if)# no shut
The actual running-config is:
ASA01# sh run
: Saved
ASA Version 8.2(5)
hostname ASA01
domain-name test.com
enable password .... encrypted
no mac-address auto
interface GigabitEthernet0/0
duplex full
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
shutdown
interface Management0/0
class default
  limit-resource All 0
  limit-resource ASDM 5
  limit-resource SSH 5
  limit-resource Telnet 5
boot system disk0:/asa825-k8.bin
ftp mode passive
pager lines 24
no failover
asdm image disk0:/asdm-711.bin
no asdm history enable
arp timeout 14400
console timeout 0
admin-context admin
context admin
username cisco password xxxxxx encrypted privilege 15
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:fd73f6597a4becb484c97b09f051636f
: end
Somebody what´s happens?
Thank´s.
Fabio Robson Leandro Sat, 12/15/2012 - 05:17
Hello again,
Resolved...  before of restore, this ASA was with HA enable. I just change it to  mode single, reboot and it back to work normaly. The commands used was:
ASA01(config)# mode ?
configure mode commands/options:
  multiple   Multiple mode; mode with security contexts
  noconfirm  Do not prompt for confirmation
  single     Single mode; mode without security contexts
ASA01(config)# mode single
WARNING: This command will change the behavior of the device
WARNING: This command will initiate a Reboot
Proceed with change mode? [confirm]
Security context mode: single
*** --- SHUTDOWN NOW ---
ASA01(config)# int gi 0/0
ASA01(config-if)# ?
  authentication   authentication subcommands
  ddns             Configure dynamic DNS
  delay            Specify interface throughput delay
  hello-interval   Configures EIGRP-IPv4 hello interval
  hold-time        Configures EIGRP-IPv4 hold time
  igmp             IGMP interface commands
  ip               Configure ip addresses.
  ipv6             IPv6 interface subcommands
  mac-address      Assign MAC address to interface
  management-only  Dedicate an interface to management. Block thru traffic
  mfib             Interface Specific MFIB Control
  multicast        Configure multicast routing
  nameif           Assign name to interface
  ospf             Configure interface specific OSPF parameters
  pim              PIM interface commands
  pppoe            Configure parameters for PPPoE client
  rip              Configure interface specific RIP parameters
  security-level   Specify the security level of this interface after this
                   keyword, Eg: 0, 100 etc. The relative security level between
                   two interfaces determines the way the Adaptive Security
                   Algorithm is applied. A lower security_level interface is
                   outside relative to a higher level interface and equivalent
                   interfaces are outside to each other
  split-horizon    Configures EIGRP-IPv4 split-horizon
  summary-address  Configures EIGRP-IPv4 summary-address
Thanks!
