Pix showing wrong connections(with saA Flag )!!!!!!!!!!!
Jul 16th, 2007
Our Pix Firewall is showing unwanted TCP as well as UDP
Connections originating from Outside Interface (Sec level 0)to inside
interface (security level 100)while issuing "sh conn" command. The
things confusing me are :
1. The connectionss are shown coming from Outside Interface (which is
administratively down and whose link is also down) to the inside
interface.
2. The tcp Connections show flag saA for these instances and UDP
Connections are shown without flags.
So, it seems basically as if the Pix Firewall itself is seeing
connections which logically and Physically are not possible (as the
source IP's shown in " show conn " command for these instances come
from Outside interface which is inactive.
Moreover, when "show conn state up" command is used , correct active
connections are displayed .Can anyone explain me this faulty
occurence of intrinsic connections by the Pix Firewall and how can
these be removed.
