"switchport trunk encapsulation dot1q" command on cat 2950
Answered Question
Jul 17th, 2007
Hi all,
I'm configuring vlan on cat2950. i configured the trunk port with the command "switchport trunk encapsulation dot1q" and its giving me the invalid mark at the encapsulation word. The switch is showing that the command does not exist on it. Please can somebody help me out with an explanation to this. NB: the trunk port is connecting to an ethernet port on a microwave radio.
Correct Answer by Jon Marshall about 9 years 9 months ago
The 2950 only supports 802.1q trunking so there is no need for the encapsulation command so it is not available.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 07/17/2007 - 00:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
mahmoodmkl Tue, 07/17/2007 - 00:42
  • Gold, 750 points or more
As jon said the only encapsulation type available on 2950 is dot1q,so by default it is enabled on the port.due to this u r getting the error messg.
Mahmood
