paolo bevilacqua Tue, 07/17/2007 - 03:05
  • Hall of Fame,
    Founding Member
you have to not look at the country, but the type of application you are doing. for example, are you connected to PBX ( specify which type and interface) to telco (again specify which interface) and more importantly, what are you trying to do.
simmo Tue, 07/17/2007 - 13:03
this will be a CCM Gateway, with an E1 in UK, and T1 in US.
My concern is that just having a single .T peer will mean timeout delays, especially with variable length dial patterns. Here in AU, I use a template has about 8 dial peers to cover the variable length patterns.
Does that make sense?
I've attached an AU template that I use...
paolo bevilacqua Tue, 07/17/2007 - 13:19
  • Hall of Fame,
    Founding Member
Yes it make sense. However, if you use CCM, the correctness of the called number is enforced first at CCM level. I understand that there are CCM templates circulating for both UK and the US. Try posting as 'CCM dialplans for US and UK'.
So, it is safe to use destination-pattern with T on the gateway. If you want to configure it with the correct destination-patterns, you can do that, but it is not necessary.
simmo Tue, 07/17/2007 - 13:28
Hi and thanks for the reply which helps a lot.
one quick thing though - with SRST, which I forgot to mention - I'm guessing that the user might then experience delays in that circumstance...agree?
in the meantime I'll post for UK dial plans...thanks again...MS.
paolo bevilacqua Tue, 07/17/2007 - 13:46
  • Hall of Fame,
    Founding Member
You are right, in case of SRST operation, users may get a small post-dial delay when no punctual DPs configured.
But, using interdigit timeout set to a reasonable value of 4, it is not really a big issue.
