WDS and Access Point Authentication. How does it work ?
Jul 17th, 2007
Dear All,
APs can be authenticated through WDS against a Radius Server. But how can they authenticate without a username and a password in the Radius DB ? In the WDS settings there is nowhere a field where you can enter a username/pw of a user defined on the Radius Server !??
Thanks for your feedback.
Stephen Rodriguez Wed, 07/18/2007 - 07:09
  • Purple, 4500 points or more
You do need to have an entry in the DB for the username password of the AP. If I remember correctly the entry on the client AP is made under, Wireless Services > AP, here you can define the WDS username the AP will send. Alternately, you can use the CLI command of:
wlccp ap username < name > password 0 < password >
Referenced from here:
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.3_2_JA/configuration/guide/s32roamg.html#wp1051791
ciscoprolin Wed, 07/18/2007 - 12:04
Dear colleague,
just one more question on this - how can it be that the AP gets authenticated anyway - even if I do not enter the username/password under Wireless Services --> AP (and not via the IOS CLI) ?
Thorsten
Trending Topics - Security & Network
