GetServerInfo from CallManager 5
Jul 17th, 2007
I'm trying to use the GetServerInfo method implemented in the RisPort service.
When calling this method I always get the following error:
2007-07-17 12:31:52,301 INFO [http-8443-Processor18] security.RequestRateControl - http://schemas.cisco.com/ast/soap/action/#PerfmonPort#GetServerInfo
2007-07-17 12:31:53,533 INFO [http-8443-Processor18] risport.RisBindingImpl - https://xx.xx.xx.xx:8443/realtimeservice/services/RisPort
2007-07-17 12:31:53,548 ERROR [http-8443-Processor18] risport.CiscoSoapClientTestTrustManager - Exception in loadKeyStore() java.io.IOException: Keystore was tampered with, or password was incorrect
I know my username/password are correct because other RisPort functions like SelectCmDevice works fine.
Does anyone know how to solve this?
msabir Tue, 07/17/2007 - 10:06
I have been able to successfully call GetServerInfo using Eclipse's auto generated Web Services Client (It uses Apache Axis to read a WSDL and generate all the code to call a web service). Took me 10 mins to be up and running. I am thinking to post a blog on it. There is a way to trust the SSL certificate without importing it.
What tool are you using to generate WS client?
tharaldsen Tue, 07/17/2007 - 23:40
My mistake here...
I put the IP adress of the CCM system in the ArrayOfHosts SOAP input. This should really be the name of the hostnode.
So this thread may be closed.
prashanth.guduru Wed, 07/18/2007 - 11:44
I am trying to talk to the webservice on callmanger server doing something as simple as getPhone using the java example given in the developer guide. I have not been successful in getting a response. You seem to be have been able to do it. Can you help?
Prashanth
