H-REAP and AAA-override
Jul 17th, 2007
I need a solution for that scenario:
- one SSID
- AP is HREAP-capable
- Authentication via EAP-TLS with radius server
Depending on the radius-feetback (aaa-override) the client should work in a HREAP-VLAN or over the WLC.
I only found a fix configuration for
SSID <--> HREAP-VLAN.
Anonymous (not verified) Mon, 07/23/2007 - 10:22
I don't think such a scenario is possible. The radius server can be used to dictate which WLAN the Wireless user will use but cannot dictate whether the user will use HREAP mode or the normal mode. That configuration needs to be done on the controller on a per SSID basis.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
