CME GUI file missing?
Jul 17th, 2007
  • Bronze, 100 points or more
Hi, iam trying to setup the cme gui and have downloaded the ios and the correct gui files.However there seems to be missing the ccme.html file.I have checked a few other versions and it is missing from those aswell.
Is this right as i'm sure i've done this before and had the right file in the tar file.
cheers
mark
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Tue, 07/17/2007 - 06:52
  • Hall of Fame,
    Founding Member
This file doesn't exist and is not needed. it is just part of the URL you enter to access the GUI.
If you have copied the files into a directory, include it with "ip http path ..."
Hope this helps, please rate post if it does
rbarber21 Wed, 10/10/2007 - 03:20
I have the same problem with a 2821 I'm running CME ver 3.3 with IOS 124-3h. I've downloaded and archived the following cme-gui-3.3.0.3a.tar file.
I have, ip http path flash:
Still I don't see ccme.html in the sh flash:
The router comes with http Configuration Manager which works is this my problem?
Paolo Bevilacqua Wed, 10/10/2007 - 03:26
  • Hall of Fame,
    Founding Member
As I mentioned before:
rbarber21 Wed, 10/10/2007 - 03:32
Yes but when I enter this URL in to my browser I don't get any CME GUI pages that load. I just get page can't be displayed.
So still have a problem getting the GUI working
rbarber21 Wed, 10/10/2007 - 03:41
I appologies a reboot after the achive did the trick and ccme.html did work
