Business Hour Settings on CME
Jul 17th, 2007
We have CME and tring to setup a business hours without using auto attendant. Basically, we dont want autoattendant but still have it so that once 5.30pm arrives then the main two reception phones will automatically go to a voicemail stating office is closed.
any ideas how to do this ?
Rob Huffman Tue, 07/17/2007 - 05:12
Hi Chris,
I am thinking that maybe this CME feature would work for you;
call-forward night-service
To automatically forward calls to another number during night-service hours, use the call-forward night-service command in ephone-dn or ephone-dn-template configuration mode. To disable automatic call forwarding during night service, use the no form of this command.
call-forward night-service target-number
no call-forward night-service
Night-service hours are defined using the night-service date and night-service day commands.
An ephone-dn can have all four types of call forwarding defined at the same time: all-calls, no-answer, busy, and night-service. Each type of call forwarding can have a different forwarding destination defined in its target-number argument. If more than one type of call forwarding is in effect (is active) at one time, the precedence order for evaluating the different types is as follows:
1. call forward night-service
2. call forward all
3. call forward busy and call forward no answer
If you use an ephone-dn template to apply a command to an ephone-dn and you also use the same command in ephone-dn configuration mode for the same ephone-dn, the value that you set in ephone-dn configuration mode has priority.
Examples
The following example establishes night-service hours from 1 p.m. Saturday until 8 a.m. Monday. During that time, calls to extension 1000 (ephone-dn 1) are forwarded to extension 2346.
telephony-service
night-service day sat 13:00 12:00
night-service day sun 12:00 08:00
night-service code *1234
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a008061134b.html#wp1063536
Hope this helps!
Rob
cmelbourne Tue, 07/17/2007 - 05:28
hi,
thanks for that, when i try to do this there is no option in the ephone-dn 1 for call forward to night-serve. see below
SantryCCME(config-ephone-dn)#cALl-forward ?
all forward all calls
busy forward call on busy
max-length max number of digits allowed for CFwdAll from IP phone
noan forward call on no-answer
Rob Huffman Tue, 07/17/2007 - 05:43
Hi Chris,
Sorry, I forgot to mention that you must be running at least CME 4.0.
Let us know,
Rob
