viewing current system states and application classes in csagent?
Jul 17th, 2007
Hi There
Does anyone know where i can find information about what system states are active locally on an agent (not on the csamc) also the contents of dyn. application classes would be nice to be able to see. Maybe there is a logfile with this info? or a command in the csa directory?
tsteger1 Tue, 07/17/2007 - 21:56
Hi Jan
You can run C:\Program Files\Cisco\CSAgent\bin\csainfo.bat.
It creates csainfo.log and has a wealth of information in it (if you like to read large text files!).
You could probably parse the data you are looking for from that though I don't believe it has DAC info.
Tom
