Jagdeep Gambhir Fri, 07/20/2007 - 05:37
  • Red, 2250 points or more
DWane,
Unfortunately it is not possible. You can enable or disable it, which would be applicable to whole network.
Please rate helpful posts.
~JG
elliott.fougman Fri, 07/20/2007 - 06:52
The only option I have used a few customer sites was to enable ICMP globally, then use an ACL on the Vlan to which the ACS Server is connected. This will ensure that only system admnistrator / HP Openview could ping the ACS Server.
