Hardware change
richard.leclerc
I am writing an Emergency Plan for our call manager cluster and I am looking for a procedure to transfer the license from one node to another.
The licenses are based on the MAC address but if one node fails and I need to reinstall on a new hardware, do I need to purchase new licenses? Sometimes this takes some time before to get them.
mchandak
Level 7
Level 7
If you would be replacing the Hardware, you can use the same license. You will have to email licensing@cisco.com and have them re-generate the license file
mchandak
Level 7
Level 7
Thanks a lot.
Richard
