2 ISP's connected to 1 Pix515e?
Jul 17th, 2007
Is it possible to have 2 Internet connections to 1 Pix 515e running 7.2(2) code? I'm considering a design where there is a single firewall (only one available) but 2 paths to the internet instead of using 2 Pixs for redundancy. Is this even possible?
Overall Rating: 4 (2 ratings)
Jagdeep Gambhir Tue, 07/17/2007 - 12:01
If you are lokking for load balancing between two ISP's then this is not a supported feature at this time. The ASA only supports redundant ISP links (if one fails, the other takes over).
~JG
Please rate if helps
srue Tue, 07/17/2007 - 12:06
how are your ISP's connected to your network? are they T1's? Ethernet drops? Is there any sort of router(s) between the PIX and the ISPs?
rolandshum Wed, 07/18/2007 - 07:21
Each ISP has a router on site that terminates the T1's. The hand off to me is Ethernet. There are no routers between the Pix and the ISPs routers.
