Looking for a way to execute the 'copy run tftp' command on several rtrs
Answered Question
Jul 17th, 2007
We have CiscoWorks RME's Netconfig tool but I don't see how to answer input from the 'copy run tftp' command.
Example:
router1#copy run tftp
Address or name of remote host []? 10.10.10.1
Destination filename [router1-confg]? < The Enter key has to be pressed for this prompt>
12286 bytes copied in 0.472 secs
Any suggestions or input is appreciated
Correct Answer by Martin Ermel about 9 years 6 months ago
this is from the on-line help:
Using NetConfig User-defined Templates and Adhoc Tasks
You can enter an interactive command in the Enter CLI Commands area, using the following syntax:
CLI Commandcommand response 1 command response 2
tag is case-sensitive and this must be entered in uppercase only.
Example
For a Catalyst device, a clear counters command will give the following output
c5000# (enable) clear counters This command will reset all MAC and port counters reported
in CLI and SNMP. Do you want to continue (y/n) [n]?
To clear the counter, the syntax is:
clear counters y
To accept the default, the syntaxes are:
clear counters n
or
clear counters
To accept the default value, you do not need o enter any values after the tag .
and that is what Joe wrote in another thread about the meaning of :
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddb738e
This is a popular misconception. The actually means "response to follow". A without a response means "accept the default". If you wanted to use a different file for a write net, the command would be:
write net192.168.1.1my-rtr.cfg
And if you wanted to acknowledge each prompt explicitly:
write net192.168.1.1my-rtr.cfgy
Note: there is no trailing as the 'y' does not generate a new interactive prompt.
It is also important to note that for a given command, all responses must follow on the SAME LINE. That is, this will NOT work:
write net
192.168.1.1
my-rtr.cfg
y
and be aware that you need to have the permission to create files on you tftp server!(otherwise they must yet exist)
Overall Rating: 5 (1 ratings)
getwithrob Tue, 07/17/2007 - 06:35
The 3-RME boxes are used to backup another companies configurations for approximatley 15,000 rtrs and switches.
This company does not have access to login to the Unix boxes where these configs reside. As you know; looking up 1 or 2 or even 5 or 10 configs from the RME browser is no big deal but when you've got hundreds or thousands to do manually, it would be very time consuming and frustrating.
I'm simply trying to help an individual at this company have immediate access to all running configs for the routers he's responsible for. This way he doesn't have to come to us to get a config file.
Correct Answer
Martin Ermel Tue, 07/17/2007 - 06:49
Example
clear counters y
clear counters n
or
clear counters
write net
192.168.1.1
my-rtr.cfg
y
getwithrob Tue, 07/17/2007 - 07:06
copy running tftp 10.10.10.1
The entry above in Netconfig worked.
Thanks for the responses!
