AP Fallback again
Jul 17th, 2007
Two WLC4402 (Version AP1010's.
AP Fallback Enabled.
RF Group and Mobility group set
Sysname used to define Primary and Secondary.
Everything works except 'falling' back to the primary when it comes back online.
Does anyone have this working ?
Same problem on 4.0.217
The only bug I can find says 'fixed' but does not give a version only first detected in 4.1.169.
Any help gratefully received
Stephen Rodriguez Wed, 07/18/2007 - 07:17
I have this working in my lab. If your mobility groups are configured correctly, the AP should move when it's configured primary comes back on line, FYI the sysname applied to the controller for primary/secondary/tertiary, are case sensitive.
Run debug mac addre < AP mac address>
debug lwapp events enable
debug pm pki enable
These will let you see if the AP is sending the primary discovery request, and what response it is seeing.
plearmouth Fri, 07/20/2007 - 06:10
Hi Stephen
sysname definitely correct.
ap ending d3:20 is the one that should return to its primary controller.
Attached is a file containing the debug information.
not sure it highlights much
ericgarnel Fri, 07/20/2007 - 06:49
If I understand correctly, it is only happening to one of the APs?
If so, have you tried resetting the AP back to factory defaults?
plearmouth Fri, 07/20/2007 - 08:17
Hi Eric
There only two AP's currently as they are in lab environment.
One has WLC-A (primary),WLC-B (Secondary) and the other is reversed.
Neither failback
plearmouth Fri, 07/20/2007 - 08:40
No, and I have done factory resets on them because I had seperate problem with AP groups which was fixed by the reset.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
