Bandwidth upgrade
Jul 17th, 2007
We're in the process of upgrading a circuit from 256 Mb to a t-1. I've verified that the hardware is fine (though we will be upgrading hw at a later time), but have a question on the config. The only thing I would need to change on the config is serial interface, bandwidth to 1536, correct? The router is 1751, IOS 12.2(11)T10.
froggy3132000 Tue, 07/17/2007 - 09:35
the bandwidth command will not change the speed of the interface. Please post the relevant info from your config.
christopher_hal... Tue, 07/17/2007 - 09:43
Here's our current serial interface:
interface Serial0/0
description cir: 34.HCGS.416547
bandwidth 256
no ip address
encapsulation frame-relay IETF
no fair-queue
service-module t1 timeslots 1-4
frame-relay lmi-type ansi
interface Serial0/0.100 point-to-point
description lexington to host
bandwidth 256
ip address
no cdp enable
frame-relay interface-dlci 100 IETF
mohammedmahmoud Tue, 07/17/2007 - 10:19
Hi Chris,
No, the bandwidth command is used by routing protocols, QoS and other tools, it doesn't control the physical speed of the interface, the CSU/DSU connected to this interface controls the speed, i guess your provider will do this for you.
Mohammed Mahmoud.
sundar.palaniappan Tue, 07/17/2007 - 10:35
The only change required to use the full T1 is to enable the service module t1 timeslots all command.
int s0/0
service-module t1 timeslots all
mohammedmahmoud Tue, 07/17/2007 - 10:41
You are totally correct, i've missed that this is a channelized interface, and Chris please make sure that your provider has modified the T.S configuration on the CSU/DSU to match yours.
Mohammed Mahmoud.
