i see my extension of phone number on pstn phone
Answered Question
Jul 17th, 2007
I will like not to see my extenxion on the pstn phone, only my PRI DOD
which command i have to put to not allow my extension number on the pstn number.
When somebody on the outside(PSTN) don't see my extension, but only a the same number that represent all my extension in my office ?
Correct Answer by Brandon Buffin about 9 years 6 months ago
One option in this case is to use a voice translation rule to translate the calling number. Take a look at the following link. The translation profile can also be applied at the voice port level which would reduce the required configuration if all calls out of the PRI should have the same caller ID.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a0080816cac.shtml
Hope this helps.
Brandon
Overall Rating: 5 (3 ratings)
Brandon Buffin Tue, 07/17/2007 - 08:42
You can accomplish this several ways. If you want all calls going out of the PRI to have the same caller ID, set the Caller ID DN field in gateway configuration to the caller ID that you would like presented to the PSTN.
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin Tue, 07/17/2007 - 08:49
In CCM administration, go to Device -> Gateway and find and click on your gateway. If this is an H.323 gateway, you will see Caller ID DN under Outbound Calls on the main page. If this is an MGCP gateway, you will need to choose the PRI port. After choosing the port, you will see Caller ID DN under Outbound Calls.
Hope this helps.
Brandon
Correct Answer
Brandon Buffin Tue, 07/17/2007 - 09:19
Hope this helps.
Brandon
