07-17-2007 08:22 AM - edited 03-03-2019 05:54 PM
How do I add this to a router?
interface ATM0/0/0
description ATM Circuit 24.HCGJ.xxxxxx
no ip address
no scrambling-payload
no atm ilmi-keepalive
interface ATM0/0/0.36 point-to-point
description Grant Street
ip address 10.XXX.XXX.XXX 255.255.255.252
pvc 1/36
ubr 1382
encapsulation aal5snap
Thanks again!
07-17-2007 08:34 AM
interface ATM x/y
no ip address
interface ATM x/y.36 point-to-point
pvc 1/36
07-17-2007 08:38 AM
How do I add that information to router?
after going into conf t mode, do I need to type each line individually?
07-17-2007 08:45 AM
you can , or copy the above into notepad, change interface number,description and ip address, then paste all after conf t.U might have to add PVC again.
07-17-2007 08:50 AM
Thanks mohammedrafig.....
In order to cut and paste, is that done with Hyperterminal? If so, I just tried it and here's how I did that.
1.type conf t
2.copy contents from notepad
3.paste to host
after doing that, I get a % invalid input detected at ?? marker. What am I doing wrong?
07-17-2007 08:54 AM
can you send us out put of this command,
"sh ver"
07-17-2007 09:03 AM
This is sho ver
LEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 02:36 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SLB_Grant_St uptime is 20 hours, 3 minutes
System returned to ROM by reload at 20:58:49 UTC Mon Jul 16 2007
System image file is "flash:c2800nm-spservicesk9-mz.124-3g.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1122A2PV
2 FastEthernet interfaces
1 ATM interface
1 Channelized T1/PRI port
1 ATM/Voice AIM
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
07-17-2007 08:59 AM
Looks like ur router have not detected the ATM car, or u forgot to install it.
Please send the output of following command
"sh ip int brief"
"sh ver"
07-17-2007 09:05 AM
This is "sh ip int brief"
SLB_Grant_St#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.101.36.1 YES NVRAM up down
FastEthernet0/1 unassigned YES NVRAM administratively down down
ATM0/2/0 unassigned YES unset down dow
07-18-2007 07:16 AM
U should be able to add the config line by line like this,
SLB_Grant_St# conf t
SLB_Grant_St(conf)#int ATM0/2/0
no ip address
interface ATM 0/2/0.36 point-to-point
pvc 1/36
08-23-2007 08:14 AM
Hi Mohameedrafig,
I am working with another router (2811) and am trying to config the ATM interface. In last post you helped me with slb_grant. Can you please tell me how to add this command to the router?
interface ATM1/0
description 26HCGJXXXXXX
no ip address
ip nbar protocol-discovery
interface ATM1/0.36 point-to-point
bandwidth 1382
pvc 1/36
vbr-rt 1382 1382 1
tx-ring-limit 3
service-policy output Voice
interface ATM1/1
no ip address
shutdown
interface ATM1/2
no ip address
shutdown
interface ATM1/3
no ip address
shutdown
