Finding VTP Server
Answered Question
Jul 17th, 2007
I have three switches connected together in a VTP domain with two clients and one server. I can login to only one of the clients and need to figure out which of the other two are the server. BUT...I have to figure it out from the one I am logged into. Logging in to each is not an option.
Any idea how I can do this?
CDP is enabled.
Dave
Correct Answer by ankbhasi about 10 years 6 days ago
Hi Dave,
CDP will not able to find which switch is configured as VTP server in your network. In general scenario VTP client switches are always updated by VTP server switches so you can issue a command "sh vtp status" and in last line of output you will see the ip address of the switch that caused the configuration change to the database which in most of the cases is VTP server switch.
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (3 ratings)
Collin Clark Tue, 07/17/2007 - 09:31
  • Purple, 4500 points or more
Dave-
Try the command "show vtp status"
CORE11#sh vtp status
VTP Version : 2
Configuration Revision : 198
Maximum VLANs supported locally : 1005
Number of existing VLANs : 90
VTP Operating Mode : Server
VTP Domain Name : REMOVED
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x7A 0x5E 0xEA 0x88 0xCD 0xD8 0x29 0x33
Configuration last modified by 10.10.11.252 at 11-8-06 19:33:20
Local updater ID is 10.10.11.253 on interface Vl100 (lowest numbered VLAN interface found)
You can see in the 2nd from last line, it states 'who' last modified. Since only a server can, that IP is the VTP server you're looking for.
HTH and please rate.
Correct Answer
ankbhasi Tue, 07/17/2007 - 09:34
  • Cisco Employee,
Hi Dave,
Ankur
junshah22 Wed, 07/18/2007 - 21:21
Hello all,
I MEAN, can you see vtp status i.e. (server, client or transparent) of other directly connected switch......because you have only access to client switch..........
Please guide.
Junaid
