Network stretching
Jul 17th, 2007
My organization is moving to MPLS and I wanted to find out more about stretching a subnet from one location to another for disaster recovery. I was told that this can be done with MPLS, basically I need to connect the subnet to pass replication as well as heartbeat traffic. I am talking about from NY to LA. Can this be done and how would I accomplish it?
Overall Rating: 5 (1 ratings)
swaroop.potdar Tue, 07/17/2007 - 13:09
  • Blue, 1500 points or more
You can consider MPLS layer 2 circuit between the 2 locations.
But this is no different than having a private line between them. So its not only possible with MPLS.
HTH-Cheers,
Swaroop
mheusing Thu, 08/16/2007 - 01:53
  • Cisco Employee,
If you need just an "emulated Cat5 cable" connecting the two sites, Ethernet over MPLS will be a solution you should consider. VPLS is much more complex and also has hardware restrictions not found for EoMPLS. For a detailed description of supported hardware and configuration examples have a look at "MPLS AToM: Transport, Platform, and Release Specifics"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a0d17.html
and more specifically at "Ethernet over MPLS Configuration Example"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a0d1b.html#wp1058524
As Swaroop pointed out other solutions exist as well. You can also use L2TPv3 to achieve the same in an IP only environment.
Details and examples for Ethernet transport can be found at "L2TPv3: Layer 2 Tunneling Protocol Version 3"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804420e7.html
Hope this helps! Please rate all posts.
Regards, Martin
